fbr
>....What is it about a side stripe that makes the car look so different without it. >....What do others think of the stripes & what it actually does for the look? Dear Flat 6 I think the side stripes improve the length to height ratio, they remove the emphasis on the side curvature and make it appear more vertical with an apparent reduced window line (ie lower). The top up/down comparisions reinforce these effects. The stretched spider rear deck (with humps) gives a much better 'roofline' which was one of the few unattractive features of the non-spider variant. Comparing the CS with Spider (6th picture) is a good example of this, and shows the effect of the lower 'roofline' together with the reduced rear overhang of the Spider sans stripe to the CS with stripe. In short it's pre-dating the more aggressive 981 a side profile, with little increase in total length, a stretched wheelbase, shorter overhangs, apparent 'slab' sides and the much better proportions of the roof line to rear deck (ie less "pram-like"!) which makes the 981 Boxster look good with either the top up or down. If they did produce a 981 Spider, in addition to the obligatory ride height reduction they may need to chop the windscreen to achieve the required 'dash' (cf 356 variants) and definitely get rid of the Spider soft top, which looks like a knotted hankie on a bald head on a hot day!. Possible failing of the 981 style is the apparent width to length relation, in short it looks a bit porky
. Maybe stripes do make them go faster? FBR
