And this is it being written back in the beginning[ORIGINAL: rob.kellock I think this thread is now the Spyder bible!!
The tools of the refitting badge trade [ORIGINAL: rob.kellock liking the Spyder only badge
Should have gone to Spec Savers [ORIGINAL: flat6 Brian, that red car does have bumperettes. The pic is taken dead straight on and does look like indentations but tell your brain that they are actually protruding and you'll see the bumperettes. It's a trick with the shadow and lighting that makes it almost look like it could be either[]
Daro 911 you are about 3 ml out off centre badge should be over to the left a bit ,But a blind man running for a bus won't notice it.[ORIGINAL: daro911Black tips means no PSE and last night project for my car was the return of the Spyder badge[ORIGINAL: kitchens Looks like he has set of wheels for every occasion .thought all the US cars had Bumberettes fitted .Like the Spyder only badge but not the black exhausts tips prefer the chromed ones] Took longer to place on the actual car than refitting fresh double sided tape. If anyone wants some 50mm wide tape I have miles of it to spare
Yep had to do exactly that ... Your 3m clear sticky tape sounds an even better planORIGINAL: kitchensI take it you had to scalpel round the script ,i got a piece of 3m type clear sticky tape and you just rub it on like letra set and you are left with sticky badge brilliant stuff .![]()
thanks mr d for the warning to never go on a forum that is clearly populated by a bunch of ............ORIGINAL: MrDemon Stops you being called gay on Piston heads, which does get tiring !!!
OMG does that mean I need to stick the Boxster badge back onORIGINAL: MrDemon Stops you being called gay on Piston heads, which does get tiring !!!
I'm not really sure that's enough [ORIGINAL: MrDemon Stops you being called gay on Piston heads, which does get tiring !!!
Thanks flat6. Yep, the car was at idle. You can hear the diff, but it's not as prominent as it was in my old 996 C4S (and that did sound good!). Tyres are actually Pirelli PZero N2 - still the original set apparently (not surprising due to minimal mileage!). Will get to work on that interior ... once it bl00dy stops raining!ORIGINAL: flat6 Looks the business[] Yeah if you've had high winds on the motorway, you'll have heard the worst from the top. It's all up and up from there. Not teaching you to suck eggs but, I have seen people revving a car and switching the PSE on an off. In that scenario the flaps cannot close until the exchaust gasses had reduced, so switch it at idle revs and you should notice the difference. Sorry if i'm stating the obvious. What tyres did yours come with? I'm guessing Bridgestone or Goodyear[
] You just need a shot of the interior now to complete the album[
i know a good urologist[ORIGINAL: MrDemon I have Black nuts
