- Thread starter daro911
I actually think these mods work. I like it [8D]ORIGINAL: flat6 New page new pics![]()
spyderwhite
no i have tried cannot make sense of paste the link? picture into a post?i am trying to upload from my photosORIGINAL: flat6Hi. If you paste the link to a picture into a post, use your mouse to highlight all the text of link and then click the grey button that is labelled 'image'. Don't use the option which says "Click here to upload"ORIGINAL: spyderwhite i tried to upload a picture but come out as an attachment?
MrD i'm no expert driving expert but my car certainly doesn't feel like it significantly understeers. I expect Porsche sets the cars up to be controllable in the hands of the majority and then those who want something more extreme or know exactly what they want, will have to tweak it. So I don't feel I have an understeer problem. That said, doesn't understeer make a car more controllable and forgiving at the limit? If you have understeer, you can apply some more turn in whilst on the gas with less risk of overdoing it into oversteer. If the car is set up to turn in sharply, then for the average Joe, if he overdoes it on a corner and loses some rear traction, isn't he more likely to oversteer off the road or into a spin? As I say, those who know exactly what set-up they want can tweak it, but it wouldn't surprise me if Porsche have achieved exactly what they set out to by not making the car too unforgiving for the average pilot and more progressively controllable at the limit. Last week the car got pushed into oversteer. Yes it was damp but something else must've been on the road I think. I wasn't going that fast but I applied some power as I went through a green light and turned onto adjoining road, so maybe I was going faster than I thought as these cars carry a fair bit of speed through some tight corners. The back end got loose and I was heading for the curb. The when the traction regained, the car snapped straight and I was saved. It was a horrible moment though. My said I applied some opposite lock (yes he knows what he's talking about and beats me on GT5 and knows how to drift on Need for Speed!). I guess I did it automatically and don't recall that myself and hence the car pulled straight when the back wheels got a bite again, but I wouldn't want my car with a reduced tendency to understeer as that occurence may happen more often. Each to their own of course!ORIGINAL: MrDemon Will try the 7mm front spacers later to see if that helps turn in more. You guys need to change the camber and toe though, car feels on rails now in the corners for road use. I found both a bit annoying when pushed even for road, why these cars are still set for large under steer is annoying.
If you start to have under steer, and you apply more turn in, you will get more under steer. If you apply more gas you will get even more under steer. You grip has gone so doing either of the above makes it worse. All about slip angles. I hate the feeling, you pray you get grip, the only thing you can do is let off which tucks the noise back in but can cause life off over steer, or wind the steering back a bit. with oversteer at least you can do some thing about it. Not that my car over steers, it just much better balanced now and does not push like it did before. The LSD don,t help, pushing more , but does help in the over steer department giving you rear traction. Look at your oem cambers, the rear is set quite high vs the front, so mid corner you getting the full patch on the rear tyre while the front is rolling off the shoulders. I was wearing my outer edge on the front and not even using all the tyre on the rear. Which is a crazy oem set up. Now all I want to do is go out and drive, but my gf thinks I am mad wanting to go out at 10pm for a drive to know where lol. My car is night and day running -1.2 over oem for the better by a long way. Do the chalk test on you tyres and see how much or how little of the tyre you are using. I see wannabe with loads of camber, but don't drive fast enough to use it, so pointless, it's quite funny on a track day. Not that I am a pro race driver or any thing, I feel quite slow these days, must be getting old.ORIGINAL: flat6MrD i'm no expert driving expert but my car certainly doesn't feel like it significantly understeers. I expect Porsche sets the cars up to be controllable in the hands of the majority and then those who want something more extreme or know exactly what they want, will have to tweak it. So I don't feel I have an understeer problem. That said, doesn't understeer make a car more controllable and forgiving at the limit? If you have understeer, you can apply some more turn in whilst on the gas with less risk of overdoing it into oversteer.ORIGINAL: MrDemon Will try the 7mm front spacers later to see if that helps turn in more. You guys need to change the camber and toe though, car feels on rails now in the corners for road use. I found both a bit annoying when pushed even for road, why these cars are still set for large under steer is annoying.![]()
kitchens
That's not a noise it's MUSIC at it's very best[ORIGINAL: flat6 Is this enough noise for you guys?[] https://www.youtube.com/watch?v=ZJEInvyg30c https://www.youtube.com/watch?feature=fvwp&v=od6SitPYhs4&NR=1
Good to hear you're getting out and about in it Brian. I got my car back yesterday after getting the wind deflector clips replaced. Not that it stopped me getting the roof off, but it's just in time for the good weather predicted this weekend. Also got 4 new tyres begging to convince me that they were worth it[ORIGINAL: kitchens Just been out for a blast with some guys on PH some stunning cars .Dodge Viper.Ferrari 358 and 460 Lambo. Boxster. 964 . Skoda VRS Lotus Elese and various hot hatch's ,Went up the old military road around Loch lomand . Stopped in a lay by looking down on Faslane submarine base stunning road and views sorry no pics .And hood down all the way 100mls Brian
flat6 you could have done Mr D tyre inspection and got an idea on how your geo currently set is wearing and gripping or am I misreading all the data above Where you not tempted to have tracking checked whilst fitting four new boots[&o]ORIGINAL: flat6 got 4 new tyres begging to convince me that they were worth it[]
It's a good question. I didn't think of it but they tyres wore so evenly and I took them down to 2.x mm across the whole of each of the tyres. I really couldn't ask for more. Nothing was lost due to uneven wear and I got my money's worth I think. Take a look at this Michelin tyre (no it's not my car). The out edge tread is so shallow even when new. But at the end of the life of the tyre, it still even has some tread in that outer section. They use a varied rubber compound across the tyre.ORIGINAL: daro911flat6 you could have done Mr D tyre inspection and got an idea on how your geo currently set is wearing and gripping or am I misreading all the data above Where you not tempted to have tracking checked whilst fitting four new boots[&o]ORIGINAL: flat6 got 4 new tyres begging to convince me that they were worth it[]
We will be expecting a report on how different they feel[ORIGINAL: MrDemon soon![]()
