Sounds like the steering is off the Spyder version
I bet its the class leader once the road reviews appear but give me a 981 Spyder everyday of the week - Had a quick play and an "S" would run me out at circa £62k!
[h1]Porsche 718 Boxster - full details[/h1][link=http://www.pistonheads.com/gassing/profile.asp?memberId=203188]Dan Trent[/link] posted on Wednesday, January 27, 2016 in [link=http://www.pistonheads.com/news/ph-germancars]German cars[/link]The four-cylinder turbocharged Boxster is here - vital info and stats now official
It's one that we've known about for a while and the day some have been fearing, but details of the turbocharged [link=http://www.pistonheads.com/news/ph-germancars/four-cylinder-boxster-and-cayman-confirmed/33429]Porsche 718 Boxster[/link] have now been confirmed. Boxster and [link=http://www.pistonheads.com/features/ph-features/driven-porsche-boxster-s/26893]Boxster S[/link] become 718 Boxster and 718 Boxster S, lose two cylinders, gain a turbo and bang another nail into the coffin of the normally-aspirated sports car. At this stage Porsche is only releasing details for the 718 Boxster range; those for the 718 Cayman will surely follow soon, along with confirmation of the new pricing structure that makes the coupe the entry level to the Porsche sports car range and the Boxster the pricier of the two. [link=http://images.pistonheads.com/nimg/33652/718_boxster_020-L.jpg]
[/link] Bear with us as there's quite a bit of number crunching to follow, condensed below in a comparison table with the outgoing normally-aspirated versions for reference. But the headlines are the change from a 265hp 2.7 to a 300hp 2.0-litre engine in the Boxster and from a 315hp 3.4-litre to 350hp 2.5-litre in the S. Both new engines are boxer fours with a single turbo. On the S this is a variable vane item - key technology previously reserved exclusively for the senior 911 Turbo models, the new [link=http://www.pistonheads.com/news/ph-germancars/new-porsche-911--the-tech/32882]991.II turbo Carreras[/link] using two conventional ones. Porsche isn't going into details but you'd expect it's gone to the trouble to make sure the new motor's range and response sufficiently compensates for the loss of two cylinders, this being a bigger hurdle than faced by the Carrera.Horsepower gains aren't the main story with the new engines though - the huge increase in torque and where it appears in the rev range will be the real difference. The Boxster leaps from 206lb ft to 280lb ft, the S from 265lb ft to 310lb ft, meaning the entry level Boxster has more torque than the [link=http://www.pistonheads.com/news/ph-driven/porsche-boxster-gts-review/30005]outgoing GTS[/link]. All sounding good so far, right? Prepare your furrowed brow for the next bit...
[link=http://images.pistonheads.com/nimg/33652/718_boxster_019-L.jpg]
[/link]Boxster now either with a 2.0 or 2.5-litre flat-four In the modern style the turbo engines deliver their peak torque from very low revs; 1,950rpm in the Boxster and 1,900rpm in the S, both maintaining this to 4,500rpm. Which, in a twist of fate that'll not be lost on fans of normally-aspirated motors, is exactly the point where the six-cylinder engines were coming on cam and delivering their best.Your opinion on this one key character trait will define any further conversation about the pros or cons of the Boxster/Cayman range going turbo. In the 911 it's made for a more tractable, flexible and exploitable car at the cost of the [link=http://www.pistonheads.com/news/ph-driven/has-turbocharging-ruined-the-911/33571]high-revving excitement[/link] diehards will say defines the Porsche experience. The difference in the 718 range will be even more marked, given the loss of two cylinders and significant reduction in capacity. More power, torque and performance will always be welcome. But Porsche needs its new engine to have the necessary fizz and zing, as well as do the impressive numbers. We'll have to wait and see on that. Will the normally-aspirated six live on in halo models like the [link=http://www.pistonheads.com/road-tests/porsche/porsche-boxster-spyder-driven/33298]Boxster Spyder[/link] and Cayman GT4? Porsche isn't saying so far but, if not, expect the desirability of these cars to be increased yet further.
[link=http://images.pistonheads.com/nimg/33652/718_boxster_012-L.jpg]
[/link]Boxster S now a £50K car, £3K more than before For the full performance stats see below; so far Porsche has only released 'best case' acceleration figures for cars with PDK transmission and optional Sports Chrono. Like for like with the existing cars the 718 S's 4.2 seconds is half a second quicker than an equivalent Boxster GTS and six tenths faster than a PDK/Sports Chrono equipped S. The standard 718 Boxster is a whole second quicker off the line than an equivalently specced current car too. The difference is less marked in terms of top speed but it's clear the 718s will feel a lot quicker at regular road speeds. This will no doubt be helped by a kerbweight that only climbs by 5kg for the Boxster and 15kg for the Boxster S.Aesthetically more has changed than you might think from your first glance at the pics. Porsche says only the luggage lids, windscreen and soft-top are carried over, with new lights front and rear, bigger intakes on the front and sides and new Porsche script revealed when the rear spoiler emerges from the bodywork.
Chassis-wise steering is 10 per cent 'more direct', there's the option of PASM with a 10mm ride height drop and, for the S, PASM Sport which runs 20mm lower than standard. The optional Sport Chrono package adds an individual mode to the rotary mode switch; if you've got PDK too you get a Sport Response Button in the middle of it for a 20-second novelty 'push to pass' function.
[link=http://images.pistonheads.com/nimg/33652/718_boxster_022-L.jpg]
[/link]Right move? Wrong move? The only move? Inside there's Porsche's new PCM system which, inevitably, can be "extended with optional modules to thoroughly adapt it to personal requirements." Ready that options list... Speaking of money the new 718 Boxster starts at £41,739 - nearly two grand more than the current model - while the S is £50,695, a leap of nearly £3,000. Deliveries start in the spring.So that's the initial number crunching out of the way. But the debate about the merits of the new turbo engines promises to run and run with the proof, as ever, being in the driving. Noise, response, character - these things will matter to many on PH. Will they be as important for the broader customer base, raised on turbos, impressed by the significant spec sheet gains and considering the faster, more frugal 718 Boxster a demonstration of more bang for your buck?
This one will continue for a while...
[link=http://www.pistonheads.com/classifieds?Category=used-cars&M=1538] [/link]
Boxster718 BoxsterBoxster S718 Boxster SEngine2.7-litre 6-cyl2.0-litre 4-cyl turbo3.4-litre 6-cyl2.5-litre 4-cyl turboTransmission6-speed manual/7-speed PDK6-speed manual/7-speed PDK6-speed manual/7-speed PDK6-speed manual/7-speed PDKPower (hp)265@6,700rpm300@6,500rpm315@6,700rpm350@6,500rpmTorque (lb ft)206@4,500 - 6,500rpm280@1,950 - 4,500rpm265@4,500 - 5,800rpm310@1,900 - 4,500rpm0-62mph5.8sec/5.7sec PDK (5.5sec Sport Plus)5.1sec/4.7sec PDK (Sport Plus)5.1sec/5.0sec (4.8sec Sport Plus)4.6sec/4.2sec PDK (Sport Plus)Top speed164/162170173/172177Weight (kg)*1,405/1,4351,410/1,4401,415/1,4451,430/1,460Combined MPG33.6/35.838.2/40.931.4/34.434.9/38.7CO2 (g/km)195/183168/158211/190184/167Basic list price£39,553/£41,475£41,739/£43,661£47,858/£49,780£50,695/£53,5
