ORIGINAL: sawood12
Personally I don't see the point in replacing body panels with CF or GRP unless you are going the whole hog like Neil and going for a track dedicated car. For a predominantly street car where you want to retain some of the creature comforts and not compromise aesthetics too much I think the opportunities for significant weight loss is limited.
If you haven't already, I really think you ought to give weight reduction a try in these cars, maybe not the panels but even small changes make a big difference, I've been able to feel almost every change I've made over the years. I think it would be very easy to keep most of the creature comforts (does anyone really need electric seats - without a memory setting pretty useless) and still save a reasonable amount of weight.
I suppose what I'm saying it, if you just remove 50kg from the car (all possible in under an hour and just as easy to reinstate - remove the passenger seat, rear seat back, spare tyre, boot carpet), I'd be amazed if you didn't notice a very substantial improvement. Clubsport and RS Porsches do not always have huge weight savings, which I think helps show a little change can make a big difference.
Regarding aesthetics, after market panels can be very convincing, for example I don't think many people would know I have GF wings without me pointing it out to them. The bonnet I have is a little more noticeable (and amusingly I noticed when getting it into sunlight the other day that the bonnet they must have taken the mould from had an indentation where its been pushed down to close it, many 944's have this so I suppose I could claim it actually makes it more accurate a copy [8|]).
ORIGINAL: sawood12
In anycase even at 1300kg's or so I don't consider our cars to be that heavy when compared to other modern sportscars and hot hatches. Even a GT3 is around the same weight, so I don't agree with the notion that our cars are particularly heavy.
It seems a lot of people that have weighed 944's have found them to be much heavier than expected. However I'm not sure how accurate modern car weights are in comparison. The temptation for me is to look at a car like the GT3 and see how we get close to or exceed its power to weight for a fraction of the cost, then we can really start to have some fun...
ORIGINAL: sawood12
I do think there is an oppportunity to do something with the rear hatch though. That is one area where the weight can be significantly reduced and C of G lowered. Its a shame there isn't a Polycarbonate or Lexan hatch intended and more suitable for street use. It would certainly help to eliminate the creeking hatch syndrome.
It's definately a good saving, and would be first on my list after doing the seats and the like. I think you can get screens suitable for street use, my new one should hopefully last well (it's got all the latest coatings) and is really well made. The only downside is you may not get such a good seal around the edges, depending upon how well the frame is fitted. My old cheap and nasty screen was useable for about 3 years (I kept it on for much longer...) but then it was left outside all the time which caused discolouration.
