Well I had my car setup today, bit of a hassle but have a starting point.
What was interesting was my car ride height was way more than oem ie 7mm higher, I scrape already so it was a shock to find my car rides higher than oem by that much !
I decided not to lower it though, as I said I already have scraping issues !
Geo was just about spot on oem bar right rear toe which was out, that would explain my snap to the left under braking VERY hard which was a shock, it was only just out as well but enough to really unsettle the car under very hard brakes, I just though it was my disks and pads bedding in, but that rear toe being out on one wheel explains a lot. (out by 6 minutes)
I have PDSL in my car so there is a shim (2mm) extra in the car on the LCA for that plus a stock 8mm shim, I then also added another 8mm shim so 18mm of shims up front.
this gave me 16mm more front track which is nice and I got the car dialed into -2.3 camber up front with zero toe in. (if you don't have PDSL buy a 2x 10mm spacers to get the same)
The rear was hassle even with my new toe links (buy CUP ones if any one wants to do this these are 40cm longer than GT4 oem ones ! ) there is a small oem shim in the rear LCA but even with my new Toe links we were still having issues, so then had to add another extra 5mm shim to the rear LCA, I did not want to go crazy with rear camber as my inners are wearing faster already on the oem geo, I see many people goto -2.2 at the rear but I am pretty sure with the rear ARB on full still my car is not rolling as much at the rear to want that much camber, so I have taken a punt at -1.8 camber at the rear and will pyro the tyres on my next track day.
I put rear toe up just a tad to 11 minutes each side, this should make the car stable under hard brakes, and of course the new toe links are monoball so again no rear steer coming from rubber bush's now on that part.
No idea how it drives as the trip home was a river, I needed a boat really ! all I can say is that it seems to brake nice and straight and it drives nice and straight, more to come on the driving front
I hated the cars at PEC to a point I was not even looking forward to mine coming :-( , and the snap under braking on my car plus the dire oem understeer, I was not even happy driving mine, I am hoping I can fall in love with the GT4 rather than keep slating it.
even if you dare not change parts which many don't like doing , it's well worth a geo to see if everything is perfect before any track day ! , mine was out so little but still gave me a shock under aggressive braking !
