Peter Empson
Here's a pic that shows my setup, the seat here is positioned in my normal driving position. In real life the distance seems to be even greater than is shown in the picture.
ORIGINAL: 944 man
You would concede though, that a bolt-in cage is designed so as to not add structural rigidity, as far as is possible (this is why connecting to the suspension mounts/strut tops is not permitted)?
ORIGINAL: 944 man
ORIGINAL: 944 man
John; you're missing the point. Do you honestly believe that a simple six-point bolt in cage adds structural rigidity? All it really adds is weight high-up, compromising a vehicles handling to some degree, never improving it.
ORIGINAL: appletonn
Well a 'simple' bolt in front strut brace adds rigidity to the front supensions towers, so a bolt in cage, however 'simple', must add some rigidity to the body structure, albeit not as much as a welded in cage.
ORIGINAL: 944 man
ORIGINAL: appletonn
Nonesnse Nick. A 'simple' strut brace (useless without a triangulated brace btw) is only able to stop the strut towers pushing together.
There is a lot of repeated opinion in this thread, but very little real knowledge.
ORIGINAL: 944 man
......where a proper multipoint cage isnt permitted by the rules.....
ORIGINAL: Fen
...... There are lots of more standard classes that exclude triangulation of cages to the suspension, particularly the front where the cage would otherwise go nowhere near the suspension mounts. This I have always assumed is to keep perparation costs down by preventing some people from using the cage required to meet safety regulations from using it to gain significant extra rigidity.....
ORIGINAL: 944 man
....... You havent added any worthwhile strength, because the suspension mountings are still all unreinforced, but you have reduced the area of the structure which is able to absorb the still present flex/movement...
.....Its a good job that I didnt mention anything about not running List 1B or slick tyres in an unprepared chassis..... []
