Helen Goff
No.1 Poster
isn't there a oil that is thin when hot and gets thicker as it cools????
if not then there should be[
seems to me the RMS only leaks when the car is cold. eg parked. so i was wondering if using an oil thats thicker when cold would help
sounds to me like you are one of the lucky ones whose got a Boxster without this problem. my 2000 Boxster with 43K on the clock has had to have two RMS replacements cost is about £500ish but make a fuss and they may take pitty on you. as for when to expect it to happen. well there dosn't seem to be any rules. i've known nearly new cars have to have the RMS replaced then theres cars like yours that don't ever seem to suffer. so keep your fingers crossed and look out for tell tell spots of oil on your garage floor. but don't worry about it.ORIGINAL: al bevan
This problem may be similar to the one I have had with a VW derived 4 cylinder engine used in a light aeroplane The VW engine is an original Porsche design, and many of the parts are interchangeable. Over a period of time the crankcase distorts misaligns the crankshaft and causes the engine to tighten up when hot. From the time this starts to occur you have about 500 hours to fix it before the starter motor can't turn the engine over quickly enoughto start it, although it's not accompanied by oil leaks. It might be because of the way that the engine is suspended, (cantilevered). The only solution seems to be replacing the crankcase halves which solves the problem for about 1000 hours or so, our last replacement cost us around £5000.
You may or may not find the above relevant, but I am very interested to know what mileage I can expect RMS problems to start happening on my 2000 2.7 Boxster with 30,000 miles, and how much it will cost to fix? Replacing the seal alone seems to me to be only an interim solution.
Any advice would be appreciated.
Apparently amongst a number of Carrera GT's being PDI'd down at Reading there is an 03 reg Boxster with its engine in bits. Wonder why?
