uk66fastback
Well a bit of a nightmare this week - coming back from a pool match Thursday night at 10.30pm, the headlights decided not to pop up so had to drive home with just sidelights. Friday night i checked the three fuses - all okay. Also bought a new headlamp motor relay and proceeded to fit that ... still no good. Sat morning turned up a a mate's to continue work on his '66 Mustang coupe we've been putting back together, but I had to tell him about the headlamp problem and how I thought it was probably electircal -he's very good on auto electrics. We started with the basics - fuses okay. We checked the old relay - it worked - we checked the new relay - it didn't. Well, it worked but it wasn't doing what it should have. It LOOKED the same as the original one but two of the spades were doing things other than they should when power went to them so we junked that and went back to the original. Still no headlamp being raised. The mechanical set up wasn't binding in any way and by getting power directly to the motor we could get it to spin correctly and lift the lamps up. So, next stop - Molex switch on the motor. We weren't getting the readings we should here for some reason on the yellow/blue wire (pin one of the Molex) and suspected a busted wire between the switch and the motor. Investigated the switch, cleaned it with some special contact cleaner while we were at it, and reassembled it. Still no good. Ran a wire from the switch directly to the motor - headlamps lift - so fault between switch and motor ... we followed the yellow/blue wire as ar as we could - what a nightmare - it just disappears from view within no time! Anyway, while going through some other things and finding out whether the blue/yellow wire fused before or after the switch, we found a duff fuse in the fuse box - no. 37 - replaced that and everything works, so the fuse was indeed the gap in the power line. But before anyone says it was probably like it at the start, it definitely wasn't! But what we did to make it blow I don't know. Anyway, that wire goes from headlamp switch to fusebox and to the motor (need to get a proper wiring diagram) So thanks to my mate Chris, the headlamps now raise ... (hours later)
