what did you do to your 944 today
Much better Pete!
The ARB bushes do seem to suffer on a 944, especially if there has been a power steering leak!
Out of interest, which ball joint rebuild kit are you going for? I have looked into this previously, but many in the UK seem to suggest they don't last - can't see why not as long as the housing isn't worn out.
Hallsy said:
Much better Pete!
I've ordered the kit from design911, I have bought a lot from them in the past and have always been happy, i checked the condition of the arm first to see if any signs of cracks etc, all looks good. The other side shows no sign of play which surprised me as that side has already been fitted with a repair kit. IIRC it's about 8 years since I replaced both arms that I ordered from promax, one was new the other had had a new repair ball joint kit fitted which is still fine today. As a temporary measure we drilled and tapped the bottom cap and fitted a grease nipple just to add a little lubrication to the joint, these joints don't use grease but this should help with getting the old ball joint out next weekend. The good thing is that the bottom cap spun ok so isn't seized against the alloy recess or the C clip that holds it in place. Now that I've taken a close look at the design it's a very simple thing to repair, like you say the important thing is that the arm itself is in good condition and that the ball recess isn't worn although the repair kit looks like it's designed to take up some wear as it has an internal top cup that fits into the arm first. we won't really know until we take the thing apart, all being well I anticipate that this job shouldn't take more than half an hour to do, I will report back how it goes.
Pete
Drove White944 to Kings Lynn for the Anglia Car Auctions classic sale. Very long day and 150 mile trip. First decent run it's had, a very enjoyable drive.
coated the inner sill internally with POR15, according to the info this is the only product that protects fully against rust.....I used 3 of the parts not requiring the ceramic type coating top coat as being internal it can't get chipped. First stage was the degreaser, then left overnight to dry, before applying the metal prep I used a hairdryer to ensure all was dry, the metal prep is sprayed on and must remain wet for at least 30 mins, I kept it soaked for over an hour and then washed with water. Next stage involved drying off and then the undercoat rust preventer is applied, two coats sprayed on and then brushed in to ensure all bare metal from the welding was covered. If the top coat is to be used it's best to do this when the undercoat is touch dry, 2-6 hours, as I said I didn't need it for where it was being applied, the top coat is supposed to be impossible to chip. The whole kit is stated as being able to coat rusty perforated metal, seal the holes and make the panel solid, strong and will last a lifetime, evidently it's a well known product in the restoration industry...well it certainly sounds good, we shall see....:)
I also renewed the damaged lower arm ball joint, I bought the repair kit from Design911, on examination the kit plastic parts didn't look as good as the originals, however on close inspection of the original ball joint it was clear that the ball joint and it's caps were in perfect working order, what had failed was the spring that kept the plastic cups compressed against the ball. We decided to rebuild the ball joint using the original parts except for the spring which we replaced with the one in the kit. Testing after refitting showed that the play that had been experienced before is no longer there and a 100 mile test drive confirmed that all is as should be. The front bearing were re greased and adjusted.
Now we do have one issue which needs further investigation, as mentioned before we have been chasing a coolant leak around the top hose/bleed component, this time I flattened the alloy parts on a surface table using 240 w&d as they were a little bowed, we hoped that this would cure the leak but after refitting everything with new gaskets during warm up it was clear that there was still a coolant leak around this area, however this time the gaskets were dry? I believe that the only possibility left is a hairline crack in the head, it looses the same amount of coolant each time, dropping to just below the lower mark on the expansion tank but no lower, this is a bit of a puzzle as if the head does have a small crack in the coolant chamber I would expect to lose more coolant and then have over heating issues, I have neither?? We could just take the head off , find the crack, which if there is one must be at the front and very small and weld it. I'm travelling around Wales Monday week so this will have to wait, we will try steelseal and see if that cures the problem for now, I suspect (and hope) it will do it permanently..
Pete
Took her on a 400 mile round trip for the bank hold week end, what with the rain the roof stayed up :-( but didn't leek a drop, so thats good and didn't miss a beat...:)
Just got back from a 5 day tour around west and north wales...drove for over 11 hours today coming back home, let's just say that we took the scenic route..:)...car never missed a beat...I don't have the words to describe how happy I am with the old girl...if I was a few years younger, I guess 'wicked' might do nicely....:)
Pete
Tried to remove this damage caused by a child cycling into the wing.
It now looks like this, the mark is still there but only I can really see it:
This then highlighted how scruffy the rest of the paintwork was looking so I tried the polish on one section of the bonnet, hopefully it's obvious which section! I couldn't find the clay I had only recently bought but once I do I will finish off the rest of the car.
Fitted a new clutch master cylinder to my wife's stone grey 924S-the last one fitted last July only lasted 14 mths but ECP guarantee -12 mths.
It's a job I have done several times over the years on our 924's & I like it less each time.Replacing the actual master cylinder takes no time at all -adjusting the pedal freeplay beforehand to see if that helps is a pig of a job -lying on one's back in the footwell using my Sealey adjustable mechanics stool to support my backside-then adjusting the spring length on the assister rod is just the icing on the cake-all to no avail though the pedal freeplay needed adjusting.
The real problem is having to remove the starter motor & bleeding the slave cylinder -nearly half a jamjar of wasted fluid ,despite clamping everywhere as just a bubble or two of air lets the pedal to the floor.
I've tried using my pressure bleeding bottle before & even that proved messy & useless so back to the old favourite ,my wife pumping the pedal ( no slur intended about my wife's age -she's still lovely!:ROFLMAO:)
Good result-nice smooth pedal action,but keeping fingers crossed that the slave cylinder is still good.Also no signs of clutch slip but the necessary pedal play adjustment does suggest a likely new clutch in the future-not surprising as it's still on it's original clutch at 103K miles-the result of my wife's superb & careful driving since we acquired the car at 26K miles way back in 1991.
I've had a sticking accelerator for the last week or two, been driving me mad as everything looks in good order, C clip, base of pedal, actual pedal, Spring etc etc. Got to the point of WD40 to see if this would ease it. No such luck !!.
I have recently had the old girl in the air on axle stands and I used the front Jack points just behind the wheel arch to jack her up. One of the feedbacks I received was exactly this, it was from Waylander and he pointed out that by jacking up from the front point can cause the floor to deform slightly. As suggested I took a 4lb lump hammer to the old girl, two taps and the Job was done. Probably the cheapest fix to date, Cheers Waylander !!
Drive shafts out, o/s swing arm out, 968 beam axle rebuilt. Looked up price of new rear disc guards and had a fit. That's one old bit that will be going back.
Fitted a Firmtec shift light last night to the inside top of the binnacle. I've hit the rev limiter on track before when concentrating on cornering/overtaking/being overtaken so this was a birthday present.
Not the best manual in the world as it is a very competent and adjustable piece of kit but got it nicely set up for graduated lights starting at 5000rpm and going up every 250rpm before a change at 5750rpm. No point revving higher as the turbo is running out of puff by then.
(Or else it would be, had I not realised this morning that I wired it into the speedo feed to the EBC rather than the Rpm feed - I can't see me doing 5750mph any time soon)
Removed my instrument panel to sort my tachometer and oil gauges that aren't working. Next to figure out why they're not working. One of the easiest removals from any car i've ever worked on. 15 minutes and out, including steering wheel off.
New brake discs on front and removed ARB supports from front which I think are making my car handle quite poorly in the wet. Already have polybushed front roll bar and strut brace and felt the ARB supports left me with no give whatsoever so let's see how it goes now. Interestingly it handled great in the dry and awful in the wet, front end sliding out on roundabouts. Anybody else had a play with ARB supports? Interested in any feedback.
Stuart
ARB supports on the front seem to add to odd binding problems. NineX took mine off and TBH I am glad they did as the car was so much more fluid afterwards. I also had mega binding on my rear coilovers, the helper springs were too soft and this was causing the joining piece to bind against the threads of the damper. Again fixing this with new helpers and main springs + lubricating the ARB bushes made a big difference. It really helps a lot to make sure the cars suspension has no binding, sure the car moves around more and rolls more but crucially you can push it way way harder without suddenly loosing it as long as one is comfortable with the car moving around a lot underneath the driver.
Today I adjusted my rear ARB to full hard and checked everything prior to hopefully getting a pass out for Combe this Thursday. May be the last chance this year to get on track and I found the front left strut is leaking again a bit onto the shaft from the top seal so probably will need a rebuild in the next 6 months.
