what did you do to your 944 today
- Thread starter colin944
While you're in there jobs have consisted of removing an inch of sludge from around the AOS and replacing the obviously gone seals, having the alternator refurbed and a general clean and tidy up.
Have also had the inlet Manifold re-powder coated as it was a bit tatty and I know how much 944Man loves the red !!!
![Kiss [sm=kiss.gif] [sm=kiss.gif]](/forum/styles/default/pcgb/kiss.gif)
blade7
Well-known member
Eldavo said:I've had an issue with my turbo so removed it last week and it's been sent off to Turbo Dynamics for a bit of fettling.
What spec are you going for on the turbo ?
Should be good for up to 340-350 bhp with minimal downtime and sensible costs.
blade7 said:Did the turbo builder have a suggestion about how much boost it could run ?
Sorry - I missed this, yes - reccomended efficiency range is up to 20psi before it starts running out of puff.
At 18psi I should see around 330bhp but a lot more mid-range and much greater area under the curve as boost is held longer and comes on sooner.
Final specs are a machined out cold side housing, larger billet compressor wheel with bigger surface area, new hardened shaft with uprated 360 degree bearings and a billet replacement #8 hot side wheel.
£415 + VAT including the courier there and back.
blade7 said:Sounds like a bargain, sort out the intake tube/air filter too and it should fly. When do you expect to have it running ?
Are you in my kitchen?
Got all the 3" inlet plumbing laid out on the table [
Psenior1
Replaced rear callipers & caliper brake pipes. Changed the gearbox oil to Castrol syntrans 75/90, what came out was as black as a pint of Guiness, whine is much quieter now which is a bonus. All new front arb bushes, droplink brackets, stiffener brackets, nuts and bolts. New alternator and ps belts, replaced coolant temp sensor too.
Just sourced two new sachs front struts, so will be fitting those soon, along with a refresh of the rear arb bushes, brackets, droplinks and rear shocks if I can get hold of some for a reasonable price. Every bolt/eccentric bolt and nut on the front and rear shocks/droplinks look totally gone, so sourcing those is going to be a pita no doubt.
blade7
Well-known member
Eldavo said:blade7 said:Sounds like a bargain, sort out the intake tube/air filter too and it should fly. When do you expect to have it running ?
Got all the 3" inlet plumbing laid out on the table []
944Scott
As long as the weather is good the gearbox goes back in tomorrow.
944Scott
markrreid
[ul][*]Passenger elec window switch (on driver side) and fixed the missing retaining piece of plastic that had snapped off.[*]Rear number plate lights (nightmare getting old ones off)[*]Sunroof switch[*]Heater knobs and slider buttons[*]Rosette[*]Numerous internal bulbs and light casings[/ul]Fixed:
Digital clock (haven't re-connected battery to see if it worked yet!
chip in such a place that it seems its been clipped with something probably by the builders near my mothers house as car been parked behind or in front of there van a few times,
used paint pen to cover mark for the time being,,,,jasonp
