what did you do to your 944 today
- Thread starter colin944
jonnyporsche
she was totally bone dry[
happy days and drove so well with her new alternator and fanbelts not forgetting puncture fix,,
High numbers for a few miles and rock solid,,felt like she was cruising with lots left on the right foot,,,,,jasonp
vitesse
Then driving up the drive to Orsmkirk Golf & Country Club at the start of Porkers in The Trough 8,the rubber suspension bobbins holding up the petrol pump failed letting the feed hose from the tank drag on the ground & wear through until the pipe was spewing petrol out.
Fortunately I was alerted to the problem fairly quickly before any sparks could send me up in flames-a good friend & fellow R18 member,Rod Staples ran to get some Visegrips from the Golf Course maintenance building whilst I did my little Dutchboy impression stemming the leak.Got trailered home at the end of the day ,ordered a new pipe,tank filter but had the bobbins ,jubilee clips in my stock.
Main problem was that the tank was nearly full but had 2 x 20 litre empty plastic oil containers & used one of those plastic squeeze handpumps to drain enough util it was reasonably safe to cut right through the pipe & drain the rest using my visegrips as a "tap"-jacked up at 1 side meant that a lot of petrol drained to the side of the tank away from the outlet.
All back together-filled back with half the fuel -no leaks -started 1st time & sounded a lot sweeter /quieter at the pump.
So took for MOT (now overdue 2 weeks because of the fuel pipe) & passed but owner of the garage I always use let me get away with a slight wear on offside front balljoint plus the evergreen steering shaft slight wear & nearside handbrake efficiency a bit low.All necessary parts obtained this week at ECP including Lemforder ball joint £14.88,OE steering shaft £95.29 so just got to find the time to do the work-oh the joy of running a 30 yr old car!
Incidentally,the intank filter I removed was in very good unblocked condition & didn't really need replacing,but you don't get to know that until you remove it
vitesse
What a pity you didn't-it would have been good to put a name to a poster!-I now know Greg quite well.
We are up at Whalton at our Daughters again this weekend but not in a Porsche-our visits to lovely Northumberland never seem to fit with any R3 event ,sadly.
Can't also understand why I put "Ormskirk " instead of "Garstang " in that post?.
Yes ,just the hose from OPC -£14.85 inc VAT & discount if I remember but the intank filter was £40 or so(& not necessary really) plus some lost petrol & damaged pride ,never mind not driving the day although good friend Rob Kellock took me round in his 911 GTS-including some illegal speeds up the M55(probably helps if you are a Solicitor specialising in defending speeding motorists)
g944s2
hibeeg said:My S2 failed it's MOT on both sills.
Good news was no advisories and nothing else wrong with it!
I had the sills repaired and the car passed its MOT yesterday, very pleased, it's been missed!
Diver944
MarkK said:asked me to go "fast fast",i of course was mature and did not oblige..
You are such a fibber Mr K
PSH
Pete
Dan944t
I was thinking about my rebuild today, as my brother in law was asking me if he thinks I'll get the engine built up and in before summer next year ?
hopeing to pick up my short block, pistons, crank , head ect from serdi some time this year
PSH
Dan944t said:Been waiting for an update on your car pete
hopeing to pick up my short block, pistons, crank , head ect from serdi some time this yearIt's all been there a loooooooooong time!
Alas, these things do seem to take time Dan, I originally thought that mine would take some months, iirc it took nearly 5 years? to be fair a big chunk of this was because of my other main hobby in building live steam locomotives, that I had been neglecting due to the car. The other big factor was the hidden costs, Porsche parts aren't cheap, nor were the mods that I had decided on. I still have jobs to do, the car could do with new brakes all round, rear bushes as these are still original, as is the torque tube and it's bearings..lot's of money involved in these things and as mentioned my other hobby which sucks in just as much money as the car, probably more. I think that I may need to come out of retirement and get a job?....
Pete
Dan944t
Its funny as before the engine was damaged I had plans on changing all my bushes as there also still original , rebuilding my calipers and wanted to get the car resprayed, but hey this is how life goes.
i also have also got a million and one things on the go. I use to do allot of competition shooting and gunsmithin but that's all stopped since the turbo s engine cracked, then new house and new baby.
Lifes good though , I'll get there
