Endoman said:
Still having intermittant electrical problems. Occurs when battery is not fully charged. Will stall then not restart (no tach bounce) swap DME relay, starts.
Test old relay works fine, stick it back, starts runs all day. Crank sensor tested with o/c spot on. It's got to be a bad contact somewhere or a poor wire. Sod to find.
Its been many years since I advised on these sort of issues and my memory is not what it once was but....
I would start by removing and cleaning the ECU earths . There is a ECU earth point under the dash ,below the fuse relay box and also along the NS chassis rail. From memory I believe these are MP2 & MP3 These earths are critical as the ECU uses them to earth itself the DME relays ,injectors ,fuel pump etc Also clean the block to bulkhead earthing strap MP9 & MP10
12v+ Power for the fuel injection & ignition system and the ECU is supplied direct from the battery via the ignition switch to terminal 30 on the DME relay base. It is a permanently ON non-switched supply and should be the first check with all non start issues. No 12v on terminal 30 ?....no start no run.!
The first DME relay switch has a permanent earth -0v (pin 85) and should be the second check.
Power to the first relay switch is supplied to pin 86 on the DME relay base when the ignition is switched on This should be the third check.
(If the first relay switch has no power or a poor or missing earth then the 12v+ sitting on terminal 30 of the DME relay base will not be switched to the fuel injectors, fuel pump, ECU, and other components in the fuel & ignition system.)
Provided the ECU 'sees' the necessary feedback from all the sensors it will ground the second DME relay switch (pin 85B ) completing the fuel and ignition system supply.
It is extremely unlikely that your hard start issues are due the the crank position sensor (CPS) but its worth checking the connections .
An easy and instant test of the whole system can be made by removing the DME relay and connecting the
3x larger female spade connector terminals 87b ,87 and 30 on the DME relay base with a 3x way bypass made of wire. The fuel pump should run continuously and if the car then starts and runs on the ignition then you have temporary 'get you home' solution and have eliminated a lot of unnecessary component checks as well.
