what did you do to your 944 today
- Thread starter colin944
g944s2
PSH said:There are two types... 20x21 teeth and 20x22 teeth, IIRC the 20x21 accounts for over 90% of all 944 speedometers which I think was up to 1990.. best check though...
[link=https://www.ebay.co.uk/p/2141933657]https://www.ebay.co.uk/p/2141933657[/link]
Pete
Thanks for that, I’ve just removed it and it’s an orange gear that’s in about 4 pieces!
scam75
Well-known member
Stuart
g944s2
PSH said:colour doesn't matter.. it's probably that colour through age breaking it down...if anything like mine it just fell to pieces and was very soft due to the plastic losing it's chemical makeup.
Well I replaced the gear and put it all back together but can’t get the speedometer needle back in, I think I may have removed more than I was meant to when the needle came out, can anyone confirm from the photo?
[link=https://flic.kr/p/2mgJQWc]
The car at one point had been used without a drivers side over mat and had a wear hole in the carpet, replaced it with a nice condition one from Justin Webb (944spares.com) over time an immoboliser was fitted and the led was fitted to a hole drilled into the switch console, I replaced it with a new one again from Jutsin and fitted the led to a blank switch cover, came back to the 21st century and fitted a Blaupunkt Stockholm head unit, DAB, Hands Free, Bluetooth etc, great bit of kit that looks period, topped the interior off with a new set of Porsche overmats ££.
Yesterday new belts rollers and tensioners, oil (Royal Purple HPS 10/40) lots of zinc and keeps great oil pressure when hot at tick over, new turbo to hard pipe hose, distributor cap and rotor arm (Bosch Eurocarparts) recently repalced plug leads with new Beru items courtesy of David Chapman.
New flexible fuel lines including damper line from Dev Lyon in California.
New radiator tank cap.
Oh and a new air freshener.
Should be good for a few years now, 195 miles between MOT's.
Really need to use it now
scam75
Well-known member
scam75 said:Dropped mine off to have the head removed (details on other thread) then we can make a decision about whether the block is serviceable or needs liners (boroscope pictures not encouraging). I've always had some scoring in cylinder 2 however, noticed at last rebuild 60k miles ago. I'm hoping the boroscope pictures are making it look worse than it actually is. It does not use any oil that's noticeable. If the block does need work I do have a back-up plan. It will cost money however! [8D]
Stuart
Well the head is off and cylinder 2 bore is a mess. [&:] . 3 is a bit ropy and 1 and 4 ok. Short motor getting removed next week to be sent to AMAC engineering (along with head) for Westwood Liners and JE pistons to be fitted as well as a light skim for the head. The HG was a mess with fire rings elongated on 2 and 4 where water was getting in. 10 years old the HG which is probably the lifespan of a Victor Reinz item. So this is going to cost a small fortune, water pump will be replaced too. On the plus side the motor will be nicely sorted once it's all done! Oh well...........
Stuart
PSH
Pete.
scam75
Well-known member
The pistons look fine. Not sure about rings as the pistons are still in situ. Certainly no obvious ring damage, they were new 60k miles ago at last rebuild. The damaged bore is only damaged about a third of the way round, left side of bore if looking from drivers wing. The pistons though will not be compatible with the liners being put in so need new ones.blade7 said:Are the pistons and rings knackered too. What oil/boost have you been running?
Been running Total Quartz Racing 10w 50 fully synth for years. Running about 18 psi boost but with a MBC it peaks about 21psi in 5th before dropping back to 18/19psi.
A cometic would be a good idea, but haven't a clue what I'll need. This will be the 2nd light skim the head has had. The block so far has not been skimmed, but remains to be seen if that happens when the short motor is being rebuilt. Either way a slightly thicker than standard cometic would make sense. Will need assistance on this though guys from cometic users!
Stuart
PSH
You'll find what you need in the Porsche manual, there's a drawing showing you where to measure to calculate the thickness HG required. If I could find mine I'd post the details but alas can't find the file. There's a tab front and I think also back on the inlet manifold side which you measure down from onto a flat surface which the head needs to sit flat on. When the head is machined this distance needs to be within a given range for the pistons to clear the valves, if below you need to make up the difference by the thickness of the HG. Porsche makes two sizes, IIRC 1mm for standard and 1.2 mm for a machined head below the standard range. You can go thicker than Porsche recommend if required, for example, my Cometic HG is 60 thou thick or 1.57 mm.
Pete
blade7
Well-known member
scam75
Well-known member
I think after going to all the trouble I currently am, it would be prudent to get a slightly thicker cometic. I will ask the engineering company, who will be getting the head and block, to advise on HG and HG thickness.
Pete - Are cometic's made to measure thickness or is there a choice?
Stuart
PSH
Pete
PSH
