what did you do to your 944 today
- Thread starter colin944
I had most things to hand at work and hey, I had the time and motivation, mine was an absolute eyesore!
Chasing a top end oil leak.
It looks like oil is traveling along the join between the Head and cam tower.
So
New cam tower gasket(s)
Replaced the tappets with some NOS ones I've had in a drawer for years
Thread inserts on the fuel rail bolt holes
Some silver engine paint, sand the lettering and a coat of engine clear coat.
Not convinced I've fixed the leak, but it looks nice .
Trailing arms are going to get new bushes which appear to be available still from Porsche but aren't listed in PET on the rear axle diagram for the 1990 Turbo -
PCG501541 (was 477501541).
Kongsodoken
and cleaned all the digits whilst I was in there [
Dan944t
Hell and i mean He’ll of a lot of working out and labour especially when your lying on your back in the garage and zero time on your hands BUT !…. really getting into it now ,..
few pics below i’ve got more of the twin scroll turbo flange i had to make as there’s zero room anywhere !!!! but i’m determind to see it through …well not got much choice now
[link=https://imgur.com/a/KG3iqHl]https://imgur.com/a/KG3iqHl[/link]
Daniel
Dan944t
[link=https://imgur.com/a/HWqFcCu]https://imgur.com/a/HWqFcCu[/link]
Daniel
Dan944t
blade7 said:No offence Dan944t, but that is some ugly welding. Get the angle grinder on it.
Nice and strong is all that matters to me Blade - no offence taken mate,.. i’m a doer not a Poser….
m that’s the least of my worries mate
blade7
Well-known member
Dan944t said:blade7 said:No offence Dan944t, but that is some ugly welding. Get the angle grinder on it.
I've got some very old certificates that imply I was a coded welder in the distant past. I reckon some pigeons might have crapped on your exhaust fella
Dan944t
Blimey mate,….you even got given a certificate in the olden days ,…you must be a hell of a welder mate ,..i bet your migs look like tigsblade7 said:Dan944t said:blade7 said:No offence Dan944t, but that is some ugly welding. Get the angle grinder on it.
I've got some very old certificates that imply I was a coded welder in the distant past. I reckon some pigeons might have crapped on your exhaust fella.
blade7
Well-known member
Dan944t said:Blimey mate,….you even got given a certificate in the olden days ,…you must be a hell of a welder mate ,..i bet your migs look like tigsblade7 said:Dan944t said:blade7 said:No offence Dan944t, but that is some ugly welding. Get the angle grinder on it.
Certs were for MMA, or stick to uninformed. I understand they taught monkeys to mig. Joking aside I've welded Ali with mig in the past. It's all in the setup, and if it looks right, it quite often is.
Dan944t
ohh dear,…. i am expecting mine to fall apart then [blade7 said:Dan944t said:Blimey mate,….you even got given a certificate in the olden days ,…you must be a hell of a welder mate ,..i bet your migs look like tigsblade7 said:Dan944t said:blade7 said:No offence Dan944t, but that is some ugly welding. Get the angle grinder on it.
vitesse
I remember being on the stand for Renold Chains at the Motor Show back in 1968 with the British Oxygen stand opposite but downstairs ,when MIG sets were really just being introduced door-they were demonstrating how they could cut a large hole in a Vauxhall car front door & then repair it by letting in a piece of mild steel with virtually no distortion.
Obviously they ground off the outside but could get at the inside of the panel.
Having said that,you can't beat the old Oxford 2 or 3 phase MAG sets for heavy work like Machine Tool bodies etc but they won't produce the good results you get when welding MS to CI for example,even using nickel rods.
Many car/van rear axles were produced by MIG welding steel tubes into CI diff & hub castings.
Grinding/buffing does however allow you to check for porosity.
