ORIGINAL: geoffbateman Continued trying to get to the clutch. Manual failed to mention that the gearlever needs to be removed to get the torque tube far enough out of the clutch to allow removal. After much struggling managed to get it back far enough to access the gearlever bolts and remove it,. This allowed me to twist the torque tube round so the bell housing at the back could clear the fuel tank enough to allow me to get it a few inches clear of the clutch housing. It would appear that I would have to drop the rear suspension completely to remove it from the car but fortunately it is very smooth with no play or axial movement - phew - so that's OK as well. Finally got to all 4 bolts on the clutch housing by moving the engine front up and down with another jack and thought I was there, but oh no. The clutch release arm shaft needs to come out as it locates in the release bearing which is located into the presuure plate as the clutch works in reverse to every other car I've ever had!! The release bearing is pulled out to release the clutch so the bearing is captivated into the pressure plate diaphragm spring. What a bu**er. The shaft is in there solid and refuses to move even with a jacking bolt. The only thing I can think of at the moment is a slide hammer or to undo the cluthc bolts one by one through the starter motor aperture and lift off the pressure plate as an assembly with the housing. Deep Joy.
