What did you do with your 996 today?
- Thread starter SteveAndrews
paulossie
richardjjs1
What is this Leather restorer you
bought
This is my first forum posting, i've been particularly slack over the past months. I became a PCGB member back in Dec-15 but only yesterday logged on to the forum - shameful i know!
I am relatively new to 911 ownership, I bought my 2003 C4S in November last year and due to various work commitments i've hardly had the chance to drive her. That said i've recently had the car in for MOT at my local Independent RPM Technik and after all works required had been addressed i've started to think and plan ahead in readiness for my Euro Trip later this summer. I've known RPM Technik for over 5 years since they were previously looking after my 944 S2 Cab (which has moved on to a new home sine Feb of this year).
I have indeed this week taken RPM's advice and opted to have the infamous IMS changed (and clutch while they are down there), i've also chosen to have a Low Temp Thermostat fitted and a light weight dual mass flywheel... i test drove the RPM CSR 911 and found it wasn't at all that bad and that the chatter was minimal on idle considering the burbling exhaust note.
Not quite looking forward to picking up the bill, but I am looking forward to driving the car knowing she has a clean bill of health and 'touch wood' many trouble free miles of enjoyable driving ahead!
I will post pictures soon, but for those who maybe interested she is a Lapis Blue Manual with Savannah leather, all standard inside and out (for now).
Happy and safe driving to you all!
Surjit
First niggle - i had the aircon regassed, but its blowing hot air...
From a quick search it might be the compressor, the compressor icon on the main air con unit does not come on (or off) when i turn it on or off.
I will take it to a specialist next week to get checked over. Does this sound like the culprit? And if so, what should i be budgeting.... From a quick look I seeing number like 750... (hoping its not going to be as much as that).
Any help appreciated. I was going to try out Tower Porsche near Tower Bridge, heard good things about them and was thinking they will look after the car from here on in.
What I hadn't expected was that having put my 996 on the machine and carefully checked the readings, Chris Franklin then got his spanners out (including a specialised dedicated torque wrench for use on the locking bolts), went underneath the car and using his knowledge of what settings would be best (sports suspension and non-standard 19" wheels), used my car to demonstrate how it was adjusted!
During this he also gave the underside the once over, pointing out the replaced wishbone that needed to be waxed to keep the cam from seizing, and a missing part of the front undertray which he happened to have and gave me for later fitting!
Chris then went the even further extra mile and we took the car out for a short drive along part of his normal testing route and included many of the tests he would undertake with a paying customer to demonstrate the new geometry set-up, handling and make sure I was happy with it. The icing on the cake for me was that as well as a car that had now been set up by one of the country's leading experts, I was given a printout of the before and after settings to take away.
Having now had the opportunity to drive the car for longer and over roads more known to me, I can say that it has made a noticeable difference. It was quite good to start with and my main concern had been with tyre wear but now it just feels so much more fluid, comfortable and confident going around corners at higher speeds. Chris said the toe-in at rear had been too much and would not only have been causing excessive tyre wear, it also meant higher fuel consumption and road noise.
All that and they also provided our group with tea, coffee and pastries. What a great day (particularly for me!). Clearly they well deserve their reputation as the leading alignment specialists. We spent the full day there from 10am to 5pm. If you get the opportunity for a visit it is well worth it. I'll be enjoying my car even more now.
Robind
all oils and filters
front & rear discs
front & rear pads, sensors, clips etc
coil packs & plugs
heat shields
milltek exhaust and new tips
unblock drain plugs
steam clean engine bay and cab roof detail
tomorrow to start the detailing of the body
richardjjs1
if so don't forget to clear the drain hole at the front of the rear wheel arch (take off the wheel and there are three plastic nuts and behind there is the drain) Remove the plastic cover and clear this out. YOu may need to take the rear speaker off and again there is a piece of plastic to protect the back of the speaker and make sure the drain hole is not blocked I have clear my drain holes by the Battery out every year but missed these EITHER Don't forget to REMOVE the FRont Bumper (PU) and clear the leaves behind and around the radiator This wil take about an hour the first time you do it - 1/2 and hour once you have done it Also remove the Rear PU and check for corrosion around the rear metal bumper. Again about 1/2 first time - it now takes me 15 minutes!! Bit late now but check Prices ALWAYS with your local Porsche DEaler first Then EuroCar parts for GENUINE parts ENJOY
richardjjs1
Price might be helpful My local F1 centre charged (if you will exclude the Pun) 25.00
Robind
Thank you and yes this is cabriolet. will make sure we cover all the drains and not our first Porsche as we have a few in the collection with different part suppliers for each, most of the older stuff comes from Roger Bray or Sierra Madre (well before the pound disappeared...)richardjjs1 said:is this a convertible (Not sure if the coupe has them)
richardjjs1
OPen it half way and release the two clips that allow you to release the back window (Hopefully we are talking about the plastic window one) Remove the cover over the back (4 clips)
Then you should see a little plastic window in the middle of a aluminium unit If it needs topping up you need to get the proper Porsche oil It just makes it work better MAKE SURE YOU PUT THE CLIPS BACK ON THE REAR WINDOW otherwise you might damage to sides of the window
PS Where are you
