sawood12
Ok here's someting i've been pondering in my mind recently. What is the general feeling on aftermarket EMS systems like Motec and Wolf? I feel they have to be the best technical solution but are just very expensive which is why I guess most people on this forum that have completed big projects so far have not gone down that route. I just think that the flexibility that they can provide means you can tune the engine to modern day standards. In theory you can get rid of mapping altoghether and have every parameter of the engine contolled in a real time closed loop control system. E.G. you could have wideband O2 sensors for each cylinder with individual MAP and knock sensors for each cylinder, not to mention things like vario cam (if you were using a 968 head) so you could tune the cylinders individually for fueling and ignition in real time for every single revolution. I'd also like to see a wastegate electronically actuated and controlled by the EMS instead of a wastegate actuated by a pressure signal which would negate the need for any solenoids and pressure reducing valves - you can just programme your boost curves in the EMS. And of course in future if we would ever see a 944 with a variable vane turbo and direct fuel injection then a programmable EMS would greatly simplify the control interface. With all these modern devices fitted to the engine along with good closed loop control then 400bhp out of a 2.5ltr engine should be easy - Rick Cannell has already proved it is possible without alot of the bells and whistles i've mentioned here.
