Heater/AC unit install is near, so we checked out inside dashboard wiring. Otherwise it looked more or less OK, but wires which go to the engineroom to those big resistors were burnt more or less. Because copper wire conduct heat too good, we were forced to remove old tape a bit. After we removed a bit, we decided to remove all of it. Now it is easy to check out every single wire. We will build that damaged part and also remove badly done stereo installtion and replace it with ISO-connectors Checking burnt part of wireing
Starting point looks quite good in the picture
But it was not so good after all. Some parts were so dry, that tape was more or less loose.
Now it is easy to make all repairs. After that we will put there few rolls of Jaybird hockey tape, as usual [
] One more 951 engine. That one belongs to my friend Harri, aka Neva. Quite stock, modified KKK with Garret compressor housing and wheel. Turbine is a stock KKK #8. AFM is replaced by Link MAP piggy pack.
