Ed
Corner entry speed is a bit higher.
BUT + its a big BUT, you have to be VERY smooth on turn in + very comitted all the way through the corner, The car is very stable. You just DONT even try to adjust mid corner or youl be looking at a big bill. When you get over the initial "scare" its realy good.
The advantage is your not changing gear mid corner, therefore keeping the car stable...+ exit speed is higher...
I suspect itl be even better in a lighter weight, race car, as mine is a semi skimmed version...But as you say. 2-05 in a "semi-skimmed " road car is pretty good, even if i do say so myself.[
Ide love to try doing a 1-56 in a fully specced race car...[
Paul.
The camera is a bullet cam mounted on 3 small suckers, with the recorder in the car bolted to the roll cage.
If youve seen the second vid thats the same but facing backwards with Mr Follet following,,, "trying to keep up"....[
