AndrewCS
Hi Ralph, They certainly are and will definitely not reach the dedicated earth post / point, the negative will reach the nearside turret top nuts should that suitable ? The leads easily access - bridge the GT4`s battery`s own posts but will only attach to the M6 clamp nuts i.e. not to the large clamps themselves When you had your emergency jump did they use the earth post then ? I have never used it on the GT4 but have done several times on other, older vehicles - direct to their battery posts Begs the question ... should I configure an extension earth lead and / or carry a large M8 bolt that can be screwed in to the spare threaded socket in the nearside turret top, where our c-tek earth connection is attached ... thanks for the tip [
] All this assuming that the bonnet can be opened first
