Does a Citreon C2 count...[
]. my wifes car...
Ok so a few pictures, these are both a few that I took today and also those taken by the shop during work so far. If you compare to the photos shown in my earlier post you'd be forgiven for thinking they are two different cars... just goes to show that you don't really know what's going on under the paint or even under the bare metal.
Driver's side sill removed, it was good to see that the welding that my son did more than 6 years ago to the inner sill and torsion bar support was still good, pretty amazing considering that he did this blind with the outer sill still in lace.
the lower rear wing needed some attention... here it looks like they have drawn a line for where new metal is required.
I assume that this is the replacement part ready to go in, this also gives a foundation for the missing rear bolt behind that held the sill skirts on, the rear bolt had been missing for years.
The inner sill still looking good.
A picture of the outer sill when peeled away, the black stuff is the Por15 which was painted over the area after the inner sill was fixed, when you compare this with the photo above you can see how well it protected the metal and also how well the guys have cleaned it up.
drivers roof gutter
Hatch lip drivers side was good
passenger side needed some work
There had been a leak on the rear hatch to the left for a long time, I hadn't realised that it had rusted through.
same area after repair
Both sides of the rear corners above the bumper had small holes..I'm only going to show one side to keep post a little shorter
After repair
The rear..... now remember all these photos are work after the first pictures that I posted when they were down to bare metal... just goes to show what's found when you start probing that metal...
if you remember I said that I had supplied a new rear wing section to repair the missing lip on the passenger's side.. well here it is fitted, they decided to cut out the entire bottom rather than just replacing the lip.. top work ...
Looing at the same area from the rear.
These last pictures are what I took today..as you can see we now have some epoxy primer on ( I'm told this is very expensive) and the various panels are being checked for alignment.
The new sill fitted... you can't see the diamond for the light but it is there. Reports back are that it was a pretty good fit, just a couple mil taken off its height.
The new rear section being blended in
Lastly, I took this picture just to remind me that I need a new air filter...
The shop said that they'll give me a call later this month when she's back in paint so that I can take more pictures before the final assembly..
Pete
