Hi John,
I’m not familiar with the TracTive offerings but they look like serious fully adjustable coil-overs in the KW mould, etc., and therefore could be more suitable for track use rather than fast road driving.
I would think that something like the Bilstein B4 or B6 Damptronics would be a better [safer?] bet for your requirements, and since Bilstein are Porsche’s OE supplier probably they’d be more in tune with your CGTS’s chassis from the start?
Maybe you should contact Chris at Centre Gravity to get some experienced guidance?
A friend in R24 is also looking for a similar refresh on his 997.2 with PASM after experiencing a front damper leak, so I’ll let you know what he’s decided as and when. Someone who responded to his post has fitted some B4 Damptronics with positive results:
www.porscheclubgb.com
Jeff
997 carrera 2 s front strut replacement.. bilstein B4 or B6?
Dear all. we have a front shock/strut that has lost it's oil so looking at replacing the front pair.. so do i just replace the fronts with B4 so they are close to the spec of the originals or is it worth the extra to change all 4 corners to the B6 version... any advice/thoughts? thanks colin
Jeff
