Loads of vactaning of new panels and inside sills.Now only got loads of seem sealing to do now.Then engine out, quick rebuild.( not really needed but might as well as it's out anyway)brake pipes,fuel lines, suspension check and rebuild as nessasary,paint,and put all back together.A couple of hours work ......................................
what did you do to your 944 today
- Thread starter colin944
944Scott
Today I refitted the two small pieces of carpets in either side of the front footwells as they have had new material stitched on the side so they can be secured behind the door seal. I also fitted the newly made carpet to the back of the rear seat. Other little jobs done were, fitting the I pod cable to the becker headunit and run it to the centre storage box and fit a new gear lever complete with a crested badge in the middle.
Neil Haughey
Depends entirely on the rolling road and what sort of readings it was giving that day. Your torque reading higher than power is a little unusual, at what rpm is that maximum? Mine reads 220 Bhp and 206 lb/ft, 175k miles and some racing. My peak Bhp comes a little over 6k rpm. On mine whilst the bottom end is all original it has had the top end rebuilt, new fuel pump, injectors and no end of fettling and rolling road setup to get it spot on.ORIGINAL: jay944 had my s2 rolling roaded and was very happy with reults 191.9 bhp 194lb toqures not bad i thought for a 21 years and 140k of driving does this sound about right to other s2 owners
simdel1
I think i might have to invest in one of those!ORIGINAL: Fat Albert I ordered up this kind of Fliter remover: http://www.ebay.co.uk/itm/260881100712?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Copperman05
Seems about right if its an unchipped engine. I think mine was 199 bhp and 201ftlb after promax chip and kn filter. You may get a smidge more with sports exhaust, de-cat, decent synthetic oil, iridium plugs, etc. Also check ignition system is fit and healthy as worn leads, old plugs can mean lost horses, with the S2 its more about preserving what the engine had from factory rather than any big increases from subsequent mods. EddORIGINAL: jay944 had my s2 rolling roaded and was very happy with reults 191.9 bhp 194lb toqures not bad i thought for a 21 years and 140k of driving does this sound about right to other s2 owners
Neil Haughey
Definitely although the plugs themselves don't need to be anything special just fresh. Same for the leads, cap, rotor and coil. Fuel filter, air filter, fresh oil I wouldn't say has to be synth as this shouldn't make much difference. At this age the head gasket if it hasn't been done would almost certainly need doing, unfortunately on my race car the head has been off twice in the past year or so. First time was to replace the HG before I started racing it (had a very slight leak), 2nd time was because of a broken valve spring so the head was rebuilt. On the 968 it is always seen that a lot of the lost ponies come back after a head refresh, this idea that they only make 230 Bhp is an internet myth. Given that the heads are so similar (larger inlet valves and variocam on 968) I can't see any reason why the same wouldn't be true on an S2. I have a decat pipe on mine, just a straight piece of SS tube made for me several years back by maniflo. Rear section though is original Porsche, remembering that a car that has done this sort of age and mileage would have an exhaust full of crud by now. As such I don't believe you have to have a Dansk or whatever as even a stock replacement will be better than a 20 yr old exhaust. Unfortunately though the stock replacement is so expensive now that most would just fit the Dansk system anyway.
Copperman05
Have you tried iridium plugs? I agree most 'performance plugs' appear to be snake oil but the iridiums are different and apparently make the most difference in larger capacity engines like ours. I def feel the car is certainly more responsive on the throttle and eager to go. Similar to fitting the promax chip but to a lesser degree. Never had that with any other plug. Dont knock until you tried as they say. Good synthetic at correct viscosity = less friction, less drag, better mpg and bhp, its only subtle but you need to take advantage of what you can get on 22 yr old engine thats starting to lose its ponies, it all adds up in end... EddORIGINAL: Neil Haughey Definitely although the plugs themselves don't need to be anything special just fresh
The 3 legged oil filter wrenches are pretty rubbish for putting the filters back on. You are better getting one of these to put them back on as they take them off as well. I think the Porsche filters are 68mm, will check tomorrow. http://www.ebay.co.uk/itm/MOTORCYCLE-OIL-FILTER-WRENCH-REMOVAL-SOCKET-TOOL-68mm-FITS-SUZUKI-HF138-/270835424883?pt=UK_Motorcycle_Parts&hash=item3f0f0c9e73 Alasdair
Neil Haughey
I have one of those filter sockets, bought from Halfords.
944Scott
Ditto []ORIGINAL: JamesO I always use just my hands to re-fit the filter, then I don't need a tool to remove it for the next oil change. Not had any leaks yet.
robwright
Adjusted the gear selector mechanism so that it now isn't a nightmare to select 1st and 2nd. While I was in there I also dialled out the side to side slop by shimming up the selector with some shims that I fashioned from one of last night's beer cans. I also took the Yaris for an MOT, which it duely failed on emissions [] I knew I should have paid more attention to that check engine light that has been constantly on. Idling rich - story of my life lol. Now I have to buy an OBD2 reader and if I had to put money on it a new Denso MAF for it. Still have ordered a laptop based OBD2 reader from fleabay for 14 quid. So if anyone ever needs one give me a shout and I can lend it to you []
robwright
Exactly what I was thinking Andy. The MOT has been overdue for 2 weeks and I have been putting it off (partly because of work commitments) but mainly because it has meant I have been driving the turbo to work every day. Oh well I have 10 working days to fix the Yaris so another 10 days of morning turbo pleasure []
Black Beauty
All I did was just top her up with a bit of oil and adjust one of the headlights She needs a wash too, but that'll have to wait. S
geoffbateman
Today I have just wiped over the car and given it a nice polish. After fitting a new clutch I took it for the MOT last Friday, which was a formality, as usual. Then took the car over to Thetford to have Gladwins give it a "classic car" underbody wax treatment to keep the underside good, hopefully. It drives so much better with the new clutch in and is noticably quieter and smoother. The disintegrating torsional damper on the original friction plate was making it out of balance and causing a bad vibration especially around 3000 rpm. Now it is great, it was good before, but now it's even better. Taking it up to the Lakes next week end for the Wigton MCC "Christmas Cracker" run to give it a good shakedown.[]
